- This topic has 18 replies, 5 voices, and was last updated 8 years, 6 months ago by
Ciuraz.
2016/06/28 at 21:47 #14448
Ciuraz
ParticipantTuriu pardavimui nauju varikliu:
MXUS 1500W galiniam ratui XF40-35-45H V1 45mm magnetai 220Eur
MXUS 3000W galiniam ratui XF40-35-45H V2 4T 45mm magnetai 270Eur
Kontroleris 15FET 60V/30A su LCD ekranu ,regeneracija,
PAS davikliu, stapdziu bei gazo rankenomis 120EurTomas
86I2 669II
ciuraz@gmail.com
Vilnius-
This topic was modified 9 years, 5 months ago by
Ciuraz.
Ciuraz.
Ciuraz.
Ciuraz.
Ciuraz.
Ciuraz.
This topic was modified 9 years, 1 month ago by
Ciuraz.
2016/06/30 at 12:11 #14462
agniusmParticipantO koks tu mxus 3t kV? Koks realiai butu greitis prie 59.2V nominal 17″ rate su 3″ padanga.
This reply was modified 9 years, 5 months ago by
2016/06/30 at 13:27 #14464sopkis
ParticipantTu čia rimtai klausi ar trolini?
https://endless-sphere.com/forums/viewtopic.php?f=2&t=631422016/06/30 at 15:26 #14466
agniusmParticipantNebuvau susidures, ir neskaiciau ES tai jo, rimtai:)
2016/06/30 at 16:19 #14467sopkis
Participant3T – 12kV 59V lygu no load 700rpm, apkrauto ~600rpm (85% NVK), jei rato perimetras 1.9m tai ~68km/h
4T – 9kV 59V lygu no load 600rpm, apkrauto ~500rpm (85% NVK), jei rato perimetras 1.9m tai ~54km/h
Maždaug tokie skaičiai gaunasi.
Pataisiau vėliau, nes ant 4T suklydau ant 50rpm ir 4km/h-
2016/06/30 at 20:09 #14476
agniusmParticipantDekui. Panasiai ir susiskaiciavau.
2016/07/10 at 09:58 #14519Ciuraz
Participantup
2016/08/08 at 15:11 #14699Ciuraz
ParticipantMXUS XF40-35-45H V2 4T 3000W V2 3vnt 300Eur
MXUS XF40-35-45H V1 1500W V1 2vnt 250Eur
MXUS XF40-30H 1000W 2vnt 160Eur
Kontroleriai
MXUS 15FET 48V/30A 2vnt 120Eur
MXUS 15FET 60V/30A 2vnt 140Eur
Tomas
86I2 669II
Vilnius2016/08/12 at 16:29 #14728Ciuraz
ParticipantMXUS 1000W galiniam ratui XF40-30H 30mm magnetai 160Eur
MXUS 1500W galiniam ratui XF40-35-45H V1 45mm magnetai 250Eur
MXUS 3000W galiniam ratui XF40-35-45H V2 4T 45mm magnetai 300Eur
Kontroleris MXUS 15FET 48V/30A su LCD ekranu ,regeneracija,
PAS davikliu, stapdziu rankenomis 120EurKontroleris MXUS 15FET 60V/30A su LCD ekranu ,regeneracija,
PAS davikliu, stapdziu rankenomis 140EurTomas
86I2 669II
ciuraz@gmail.com
Vilnius2016/08/16 at 03:37 #14759
RičardasParticipantSveiki, gal kas netyčia turite sudegusį direct drive hubą ir norėtumėte parduoti? Noriu pasižaisti su variklių vyniojimu ir tuo pačiu pasiruošti varikliuką e-čiopui… Galia tinka nuo 500w iki 3kw.
2016/08/16 at 09:26 #14761Tadas
ParticipantTurim stebuklinga pyraga kilovatini su gerom apvijom bet holas sudeges vienas ir reik ji susirinkt susiderint viska daugiau mechanines dalies darbo ten.Jei ka skambink 8 sesi septyni 183257 sutarsim.
2016/10/19 at 23:23 #15060
RičardasParticipantO kuris čia magic pie?
Atspirašau, už vėlavimą stiprų… :/2016/10/21 at 06:35 #15066Tadas
ParticipantAntras jei neklystu.Nera vidinio kontrolerio buvo isvesti laidai.
2016/10/31 at 09:26 #15092Ciuraz
ParticipantMXUS 3000W galiniam ratui XF40-35-45H V1 3T 45mm magnetai 250Eur
48V 580rpm
60V 720rpmMXUS 3000W galiniam ratui XF40-35-45H V2 4T 45mm magnetai 270Eur
48V 430rpm
60V 535rpmKontroleris 15FET 60V/30A su LCD ekranu ,regeneracija,
86I2 669II
ciuraz@gmail.com
Vilnius2016/11/06 at 10:39 #15113Ciuraz
48V 580rpm
48V 430rpm
60V 535rpmKontroleris 15FET 60V/30A su LCD1 ekranu ,regeneracija,
86I2 669II
ciuraz@gmail.com
Vilnius2017/04/14 at 13:47 #15985
Tomai ar kas kitas, gal po ranka turit pardavimui 1kW MXUS ar kitą panašios kokybės variklį, hubą galiniam ratui?2017/04/16 at 10:24 #15988Ciuraz
ParticipantLabas,
Siuo metu turiu tokius Mxus
48V 580rpm
48V 430rpm
60V 535rpm2017/04/21 at 16:42 #16000
RičardasParticipant3kW daugoka, nereikia man tiek. 1kW per akis, tad vis dar laukiu pasiūlymų. Gali būti ir sudegusiom vijom ar kokiu holu atsikabinusiu, galiu persivynioti, susiremontuoti. Tik nenoriu pyragų, tie netraukia kažkaip…
EDIT(2017-05-05): Variklį jau gavau, ačiū Linas!
P.S. Čia man vienam “Edit” mygtukas normaliai neveikia?2017/06/02 at 15:04 #16210Ciuraz
ParticipantIsparduoti..
