Home Forums Skelbimai Parduodu Nissan Leaf modulius po 40Eur
Viewing 6 posts - 1 through 6 (of 6 total)
  • #16238
    Spruklys
    Parduodu Nissan Leaf modulius nuo 2011 leafo 40k myliu
    Kolkas ismatavau random keleta moduliu
    Reali talpa prie 25A iskrovimo 8.4V-6V ~53Ah
    modulio kaina 40Eur
    8 659 898 devyni septyni Vilnius
    yra 41 modulis
    kam reikia specifikacijos
    modulis:
    Number of Cells 4
    Structure 2 parallel, 2 series
    Exterior Dimension Length 303 mm
    Width 223mm
    Height 35mm
    Weight 3.8 kg
    cele:
    Cell Type Laminate Type
    Cathode Active Material LMO with LNO
    Anode Active Material Graphite
    Capacity (0.3C) 32.5 Ah
    Nominal Voltage 3.75 V
    Exterior Dimensions Length 290mm
    Width 216mm
    Weight 787 g
    Energy Density 317Wh/L 157Wh/kg
    • This topic was modified 8 years, 8 months ago by Spruklys.
    #16240
    Spruklys
    Ps. Komplekte duodu ir sujungimus, varztus, apsaugas
    #16259
    Spruklys
    Liko 25 moduliai
    • This reply was modified 8 years, 8 months ago by Spruklys.
    #16280
    Spruklys
    Moduliu nebera
    #16303
    ilgas
    Savaitei atitrukau nuo forumo ir pražiopsojau akumu dalybas. Ar dar planuoji ardyti kita baterija? Reikia 7 modulių.
    #16308
    Spruklys
    Jei pigiai gausis nupirkt tai bus. Cia turbut daug kas iesko. Man tiesiog pasiseke laiku pagriebt.
