Home Forums Skelbimai Parduodu 16s lifepo4 BMS
Viewing 19 posts - 1 through 19 (of 19 total)
  • #8351
    bondas83
    Parduodu aktyvu(Capacity) 16s lifepo4 BMS 30/60A.
    Skirtas 48V akumuliatoriui
    Ismatavimai: 60*126*21mm
    Arba keiciu i 24celiu
    Kontaktai bondas 83 eta gmai l taskas com
    #8373
    bondas83
    kaina 150lt.
    #8397
    bondas83
    BMS 16S
    1. Single Cell Over Charge Protection Voltage 3.9V±50mV
    2.Battery Pack Over Charge Protection Voltage 60V±0.2V
    3.Battery Pack Over Charge Release Voltage 56.8V±0.2V
    4.Single Cell Over Discharge Protection Voltage 2.40V±80mV
    5.Battery Pack Over Discharge Protection Voltage 38.4V±60mV
    6.Battery Pack Over Charge/Discharge Protection Release Condition Disconnect All Load to Recover to Normal State
    7.Maximal Continuous Discharging Current
    30A
    8.Maximal Pulse Discharging Current 60A
    9.Maximal Charging Current 20A
    10.Battery Pack Over Discharge Current Protection Detection Current 100A±4A
    11.Battery Pack Over Charge Protection Detection Maximal Delay Time 3 seconds
    12.Battery Pack Over Discharge Protection Detection Maximal Delay Time 1 second
    13.Battery Pack Over Discharge Current Protection Detection Maximal Delay Time 20 milliseconds
    14.Balancing System Working Static State Consume Current 200 uA(The voltage of each cells is 3.2V above.)
    15.Balancing System Working Static State Consume Current 20 uA(The voltage of each cells is 2.0V below.)
    16.Impedance 0.1mΩ(The voltage of each cells is 3.2V above.)
    17.The voltage of each cells equalization precision ±5mV—±40mV(The coherence of each cells capacity between±3%0,0.2C discharge testing method)
    18.The maximal temperature ascent of balancing system module Less than 15℃
    19.Working temperature range —20℃—–+85℃
    • This reply was modified 11 years, 6 months ago by bondas83.
    #8400
    Kam iš rcm.lt ištrynei a123 26650 skelbimą?
    #8401
    bondas83
    kad lyg ir neistryniau. Bet matau kad nebera. Gal ne i ta skilti imeciau. Bet siaip jau rezervuotas.
    #8402
    Kažkaip įdomu pasidarė kaip šitie daiktai veikia ir ar realiai veikia. Gal kas matėt kaip schema atrodo?
    #8403
    Veikia pernešdami krūvį kondensatoriais. Tas perjungiantis jungiklis tai du mosfetai. http://www.avdweb.nl/Article_files/Solarbike/BMS/Capacitive-cell-balancing-circuit-with-flying-capacitors.jpg arba http://b2600ev.org/wp-content/uploads/2009/10/capacitor-balancing.jpg
    • This reply was modified 11 years, 6 months ago by sopkis.
    #8405
    A… Na ilgokai tokiu būdu balansuos :)
    Nebent tikroji schema yra kiek kitokia.
    #8406
    Pats nebandęs tai negaliu tvirtinti, bet užsienietiškuose forumuose skaičiau kad nelabai gerai balansuoja, ne gretimos, bet iš viso pako būna ir 0.1v (3.55v-3.65v) skirtumas tarp celių įkrovus.
    #8411
    bondas83
    Jop, realiai taip ir buna, kad tarp packo buna skirtumai. O pakrovus packa atjungi ir jis per laika pats susibalansuoja. Arba jei pajugtas ir persibalansavus nukrinta itampos- tai dar dasikrauna.
    #8412
    Bet dabar pagalvojau, balansavimas veikia tik kraunant, ar ir iškraudinėjant balansuoja?
    #8413
    bondas83
    man rodos visada. net ir stovint
    #8414
    bondas83
    cia jei tarp celiu yra ±5mV—±40mV skirtumas
    #8428
    jonas
    pas mane toks bms, naudoju jau 3 metai.Šalutinis poveikis tai,kad baterija išsikrauna per kokį mėnesį ar pusantro(žiemą kai nenaudoju).
    #8440
    Taigi taigi, iš veikimo principo iškart buvo matyti kad taip bus… Galvojau gal šįkart kitaicai kažką įdomaus ir gero padarė, bet matom kad kaip visada.. :)
    Vis dar neradau rinkoje nei vieno normalaus BMS :(
    #8442
    Bet tai šiaip 10Ah akumuliatoriui iškrovimas per mėnesį-pusantro bus ~10mA iškrovimo srovė, kas nėra labai baisu. Žinant apie tokį iškrovimą galima atjungti bms arba pakrauti kas ~2 savaites.
    #8445
    bondas83
    Na as ji naudojau su 4Ah akomu. Tai jau antras menuo stovi ir tikrai neissikroves.
    #8446
    Pala pala šarūnai,otai kaip pačio bms? Juk bent savo projektams gali turėt emus bms tarkim pakoreguota plokste kad ir didesnių gabaritų kad lengviau būtų surinkt ir į trasa. Mmm?
    • This reply was modified 11 years, 6 months ago by Buckis.
    #8453
    Na jis nėra optimalus dviratinėse aplikacijose… Reikalingas 12V maitinimas, kiekvienai celei atskiras modulis. Industrija turi savo reikalavimus.
    Teoriškai tinka, bet norėtųsi ko nors pigesnio ir kompaktiškesnio.
